electrofelon
- Cherry Valley NY, Seattle, WA
A client has a 3 phase transformer intended to be a 240 delta primary to 120/208Y secondary. It is being used backwards to supply some 240 three phase loads from the 120/208 service. It is installed with the three supply phases along with a neutral connected to XO which is also jumpered to the case. I think I should remove the neutral and unbond the XO from the case yes?
