Hi all first time post here and yes I have searched the forum before posting. I am doing a side job for friend and was hoping for some validation of what I was told by the PoCo. The customer had me install a new 200a service the original was a 20 space box with every space filled with the double breakers instead of fitting a new panel (what a mess!) along with a sub panel on a 50a breaker for the hot tub. The guy is a rabid audiophile with tons of tube amps and other gear and had complained he could "hear" a voltage drop in the equipment. Sure enough when I tested it with the dryer or elec water heater on it was around 228v with both on around it was about 224v. So the PoCo engineer came out and said they would have to replace the almost 200' of #4 wire and upgrade the 10kva can. Well yesterday they came out and did the line but the lineman would not change the can saying I was miscalculating the loads as they never use close to the nameplate capacity. I tried to no avail to explain these are resistive loads and that they use pretty much what their rating is (am I correct on this?) and that they are on often. The dryer and water heater alone pull 9500w its a 4200sq. ft. house with 2 adults and 3 daughters hence almost constant laundry running. After the new line with the 9500w running we gained about 2v only and he is not very pleased thus far.
I guess my question would be does this sound like an average voltage drop? And would a larger can do a better job at raising the voltage? And yes I understand they like to undersize the cans but i'm not sure about the voltage or operating characteristics when they are running at full or over capacity. There is also a noticeable flicker in many of the lights most notably the led's when it's running like this. Thanks!
