What sort of 'soft start' control is being used? Votage control method
How long are the feeders to the compressor? 75mtrs distance
What sort of motor is used in the compressor? squirrel gage induction motor
What is the impedance rating of the transformer? Impedence voltage 6%
What is the KVA rating of the source? 2500KVA transformer
What surrounds the motor feeders (steel conduit, soil, open air, etc.)? Closed panel
Where are you measuring the voltage? at the compressor end
How are you measuring current? by RMS meter to measure peak current
What is the duration of the voltage sag? about 30 sec
Do you have any voltage measurements from the primary side of the transformer? Yes, from a feeder management relay
The number of unknowns in your question greatly exceeds the information provided.
-Jon[/QUOTE]
