petersonra
- Northern illinois
- Semi-retired engineer
I think worrying over any "grounding" issues is going to point you in the wrong direction. It is probably the least likely thing to be at issue. My guess is you could install ten ground rods at each building and not have it change a thing.
I don't see how a 60V spike is likely to cause the kind of problems you are seeing. Modern equipment can usually tolerate that kind of transient. Surge suppressors often do not even engage at that point, although I think my first point of protection would be to install surge protectors on all the panelboards and any place where I had repeated failures.
I agree with the poster who suggested an intermittent neutral. They can be very hard to find and can cause all kinds of strange symptoms.
