Switchboard sections must always remain in the upright position during installation .
I was going to say the same thing. Why is a switch board needed? Perhaps he needs a metering section?Why not a panelboard instead of a switchboard?
No metering section, it will feed meter banks. It just prefer fuses because they are much better at handling faults. again, it's just a presence of mineI was going to say the same thing. Why is a switch board needed? Perhaps he needs a metering section?
Seems like maybe a good application for letting go of a preference, but do what you must. You could look at siemens panelboards. A P4 can do fusible switches up to 200A, and a P5 will do fusible up to 1200A. Probably a lot easier to get in there.No metering section, it will feed meter banks. It just prefer fuses because they are much better at handling faults. again, it's just a presence of mine
might consider the P5, it looks decentSeems like maybe a good application for letting go of a preference, but do what you must. You could look at siemens panelboards. A P4 can do fusible switches up to 200A, and a P5 will do fusible up to 1200A. Probably a lot easier to get in there.
I use siemens for all my mid to large size panelboards. I really like them. IF you want to take a preliminary look , here is the panelboards catalog:might consider the P5, it looks decent
