travelers.
LarryFine said:
From KO to KO, so the result is effectively a single hole that all of the conductors pass through.
From the outlook of cutting the notch, it's best to use adjacent KO's. It'd be a pretty long notch if using KO's on opposite sides of the box :D
al hildenbrand said:
Cutting a notch forces the induced current to take a longer, higher resistance path, thereby reducing the induced current to a level that manages the heat.
Not just that, but in the case of one conductor in and one conductor out, both of the same circuit and a slot between them, the induced current is in opposing directions, thereby effectively cancelling the induced current.
