Coppersmith
- Tampa, FL, USA
- Electrical Contractor
I am not fond of trenching at all. Usually, the trench I need is 20 feet or less so I hand dig, and minimize the work by using IMC conduit which only has to be buried 6" but costs four times as much. This is well worth it IMHO as it saves lots of labor costs and old electrician effort.
I'm doing a job now that requires a 90 ft trench and decided hand trenching 90 ft in this heat would kill me (literally) so I rented a trenching machine. And since the trenching machine can go down 24", I decided to save money and use PVC. Here's where things went horribly wrong. Although the machine can go down 24" and all I needed was 20" it got hung up in spots (a lot of spots actually) and so I spent two hours hand digging to clean up the trench before I could dump the PVC in.
After I have the pipe in the ground and spend another hour measuring to make sure it's buried deep enough and then covering parts of it so it won't float when it rains before the inspection I have the epiphany: If I had just used IMC with the deep trench I would have avoided hours of hand digging to clean up the trench, measuring depth, and covering for rain. And I could have shot for 18" deep and saved a lot of covering work. I could have assembled and dumped the IMC and been done. Plus the machine chopped right through the roots I usually have to cut.
So my new trenching method is rent a small trencher (18" deep max), dump IMC in the trench, cover. Boom! Done! Loving it!
Perhaps this is old news to you guys and gals. If so, feel free to comment on my ignorance or spoil my good mood with facts not in evidence. Before you comment on cutting, threading, and bending, let me say this: threadless compression connectors, factory 45's/90's.
