olivierm34
New member
- Brazil
Hi!
I am having an earth leakage in my circuit and I am trying to find where it comes from.
One of the equipment installed is a trifasic transformer (Primary 380V, Secondary 380V, dy1). I begin to make some basic continuity test in order to found some insulation issues.
During that, with the transformer not energized, I discovered that, in the secondary:
- fase X and neutral make continuity
- fase X and fase Y make continuty (X / Y = 1 , 2 or 3)
In the primary, there is the same behaviour (without the neutral obviously)
Is it normal? Somebody can give an explanation?
Regards!
Regards!
