StarCat
Industrial Engineering Tech
- Moab, UT USA
- Imdustrial Engineering Technician - HVACR Electrical and Mechanical Systems
I installed a new Fuji IEC motor starter on an upgrade job for a 2 HP airfoil fan drive. Yes this is a high inertia load by my understanding.
Initial tests were without any problems and with the trip current on the overload set to Motor nameplate which is 6 AMPS on a 208V rated 2 HP Motor. This is a 6-9 amp overload, which intuition said to buy instead of a 3-6.
The overload is noted to trip at the 6 AMP setting after some run time and has to be set for 7 to stay on line, with only 5 real amps running current on the motor. So the device is more than one amp OFF seemingly.
The Tech Support where I bought the starter is telling me I need a " Trip Class 20 " starter for this type of load. He also says the scales on those devices are not very accurate, but in the past I have ALWAYS set them to nameplate without any issues whatsoever. He also says that if I get it dialed in it can work consistently more than likely.
So excuse my ignorance on Trip Class 20. Its now necessary these days to go out an do a bunch of reading on any electronic device you may want to install, before you order.
Any more advice on this particular Starter I would like to hear.
