electricmanscott
- Boston, MA
- Massachusetts Master Electrician, one man show.
Reworked some wiring for a chandelier as part of a large remodel. Removed a three way and made other end a single pole. Installed a dimmer. "Worked fine before you did anything" The problem is this. When dimmed there is intermittent brightening of the fixture. Maybe every 20-30 seconds or so the light brightens and then goes back to the level it was at. The brightening lasts for just a second. This is the only fixture I have seen that is affected.
I have isolated it to when the heating system is running. It is a new energy hog geo thermal system. So it only happens when the house is under the heavy load of the geo thermal. No other time. Apparently no other circuits.
Thoughts?
Thoughts?
