- Windsor, CO NEC: 2017
- Hospital Master Electrician
A riddle:
Got a call a while back for a bad receptacle for a TV in a bedroom. The woman said that sometimes in the middle of the night her TV would lose power, and then spontaneously come back on later.
The journeyman running the job had gone out for it, removed the wires from the stab-ins, and pigtailed all the receptacles, thinking it was a loose neutral. It happened again, and she said that she had to plug her TV into the Bath GFI with an extension cord to watch TV.
I get sent in while the j-man was away, to fix it. She lets me know that she tried a different TV in the house, same results. Try some things, scratch my head, tell her to call while the problem is happening, because at the time everything was working.
She calls again, says it's happening, and plugging into her bath GFI had the same results, so I think, loose connection at service or panel. No such luck.
Everything is ok. What's the problem? Bear in mind, two different TV's were used and the problem persisted.
[ February 06, 2005, 02:15 AM: Message edited by: georgestolz ]
