When troubleshooting a 12v transformer, like the ones used for undercabinet puck lighting, why can you only check voltage when a load is applied?
I have a Greenlee DMM and when I test off the secondary leads of the transformer I get no reading until a load is applied. Additionally, if there's much of a run between between the transformer and the lights, and I'm checking for voltage drop at the end light (where I know there's a decent VD - to the degree that the end light is noticably dim) I can't get a reading with my Greenlee, even with the load on.
In the last scenario I was able to borrow a fluke and get a reading of <4v. We changed out the transformer to a higher quality landscape transformer that solved the problem.
My questions:
1- The smaller transformers (60-100 watt) that are used for under cabinet lighting don't used windings? How do they reduce voltage? and why can't I test voltage off of the secondary leads without a load attached?
2- Is my Greenlee meter in need of an upgrade? Would a higher quality fluke style meter solve some of my problem?
My questions:
