starsandstripes
- SE Michigan
Gate movement warning beepers failed only a few months after gate openers were installed. We found a voltage reading of 18 to 20 volts ac from ground to receiver antenna on both openers. Voltage readings at both openers; L1 to L2 247 volts, L1 to ground 123 volts, L2 to ground 124 volts. The manufacturer said to drive a ground rod, which didn't do anything. They claim we have a bad ground causing stray voltage on the antenna. Wiring to the openers is three #10 in pvc underground from a 30 amp two pole breaker about 300 ft away. Meggered L1 and L2 about 75 M ohms to ground. If the ground is bad, shouldn't the voltage reading to ground be a lot less than 123 or 124 volts? Other than the beepers, the gate openers are functioning fine. Any comments would be helpful.
