starsandstripes
- SE Michigan
I was called for a duplex receptacle not working in a mid-forties house and found a reading of only 22v h-n at the nm with g in the metal 2g box. Everything reads ok in the panel and this seems to be the only outlet on this circuit.
Other readings at this outlet; h-g 60v, n-g 33v.
I checked other receptacles (not on this circuit) and found similar h-g and
n-g readings but h-n was 120v.
I did not have my inductive tester with me so I don't know for sure if the hot was truly the hot.
I don't know if this is one problem, or two different problems.
What could cause these odd voltage readings?
