c2500
- South Carolina
I own a rental condo. I am president of the owners association. The association is responsible for problems with wiring. My elderly tenant called me Friday, telling me her air did not work( and had not all week). I went over, and confirmed it. I checked breakers, and at the point of service, the 50 amp breaker was tripped. I reset it, it immediately tripped. The panel was very damp, and there was alot of corrosion below the suspect breaker (oxidized aluminum). I called out the EC who does work, and told them I was figuring the breaker was bad. (It definitely needed replacing with all the rust it had on it)
The tenant called me Friday afternoon saying everything was fine.
Tonight she called and said air was off again. I go over, the new "used" breaker is tripped. I turn the machine off at the thermostat, then tried to reset the breaker. The breaker will not reset. Finally on the 3rd try, it holds for a second then trips. I go turn the disconnect off. I go try to reset the breaker, it either trips or did not reset. The only odd thing is the breaker feels "sloppy". I am thinking short. The wire is UF. Coincidentally, a fence was added a few weeks ago. I think the post was dug in the area where the UF runs. The UF was installed in 1979. We have had it go bad in other areas. It was getting dark, and I had no tools or lighting with me.
I think the UF is bad between the point of service breaker and the disconnect.
Thoughts? Of course I have to be delicate with the EC, but used parts do annoy me.
c2500
c2500
