troublesoot help
mjf
Just trimmed out house. Installed 2 identical bathroom vent/florescent lamp/ night light combo units. Both units are wired identically. In 1 unit the florescent lamp cuts off after a short time (30 seconds to a minute and a half). Switched out the two florescent lamps and the same unit does the same thing, ruling out a bad lamp. Do I need to replace the ballast?
Any thoughts/ideas/experience with this type of situation.
Thanks in advance.
mcclary's electrical
Thanks in advance.
Does it have a thermistor?
mjf
If a thermistor cuts off w/ too much heat, than I don't believe it has a thermistor, will check paperwork on Monday.
will check the line side on monday....was end of the day when I powered everything up!!
mjf
follow up
follow up
turned out to be a bad ballast from the factory. Swapped it out and problem is solved.
Thanks all
