peter d said:It looks like when they found out it was aluminum, they gave up.
Cow said:That cut wire is SCARY!!
Cutting unfused wire inside of a metal LB with metal loppers....crazy! Maybe they checked to see if it was the neutral first?![]()
Chuckle.LarryFine said:I know! Someone had problems with a reverse-wired transformer, and was told to disconnect the neutral from the X-0.![]()
chris kennedy said:Last Friday the mech contractor lost 300' of 4/0 type W on one of my jobs. Funny thing about this is the perps cut the cable at the disco's yet took time to release the cam-locks at the tranny. Someone knew what they were doing.
peter d said:You would think the generator rental companies would spend the extra money to get the portable cable custom embossed.
peter d said:Perhaps there is more to this story than meets the eye, like a bank of transformers with the HV fuses dropped out.
What say you, Ken?
bingo you are probably right on the money with that thought.peter d said:It looks like when they found out it was aluminum, they gave up.
stew said:dang I sure hope that cut wire wasnt the neutral on a single phase run. many heartaches involved if that was the case!!!
