SAC
- Massachusetts
So what about bandwith on a paticular cable. I don't see much offerings if any for a RCA / 110 punchdown insert. Is there one?
Second I don't see any spec's out there to do so. Is there?
I know that Leviton sells a S-video 110 insert and they say limit to 75'.
I know you can get lots of stuff to work and rig almost anything.
If you would please elaborate on how you use cat-5 to RCA for a Component HD signal.
Thanks
Sparky
I've found them in both passive and amplified Decora-style inserts, combined with other connectors, keystones, as well as non-plate converters, cable in-line, etc.
That's exactly what I use, a keystone rca to 110 punchdown. I'm confused,,,,What other cable would you punch to it? It's manifactured for long runs up to 100 meters. Ever see wall to wall bigscreens in a bar when the equipment room is 250 feet away???That ain't no HDMI cable that long,,,,you can bet that(they do make mini rgb's that have 4 rg6 built into the size of a normal rg6,,,,but the connectors are expensive.This way is most economical
