Can a TVSS be connected with a tap conductor? I have a fire pump with a 600A breaker that is wired with #1 conductors. Can I land a set of #2 conductors on the 600A breaker and feed a surge suppressor without another breaker? The suppressor will only accept wire as large as #2.
Also, does anyone understand:
1. Can suppressors be installed on the line side of the service disconnect?
2. What is meant by "power frequency voltage" in 280.4?
3. How do I know what the AIC rating is for a paticular surge suppressor? (per 285.6). I don't see that in any specs.
4. I don't understand 285.21? It looks like this prevents me from installing the device on a sub-panel? It says it has to go on the main disconnect?
5. How do I nkow if article 280 or 285 applies to my device?
Steve
Steve
