How many people know what TWACS is? I can hear a meter vibrate here when I remotely read it if I’m standing next to it. Your flickering lights scenario is interesting. We are experiencing a lot of harmonics here due to a large influx of LED lighting. It is causing some flickering on led circuits. I will consider the TWAKS angle on our next complaint call and see if it’s a viable issue.How many have ever heard of TWACS causing flickering lights?
Anyone ever ran into a flickering lights problem that can’t be explained any other way other than signal modulation due to the POCO communication system?
Yeah, I have that video..The guy on the following video is showing a 60Hz waveform where the zero crossings are modulated by TWACs once in a while, and he's mentioning when the lights are flickering in response to the outbound modulation from the POCO. This occurs near 0:10, 2:24, 2:42, 2:53, and 3:08.
I'm thinking that the flickering would be more prevalent when the dimmer is turned down, because a given change in the zero crossing would be a higher percentage of the ON time of the light.
I didn't find much beyond that video.Yeah, I have that video..
That is from one guy though..
Im looking for some other experiences, if there are any.
I have a case in with Aclara looking at filters and other flickering lights cases.
also looking into the notion that all UPB dimmers are affected?
This is a separate poster from the original thread, the OP is asking a question and it does not appear to be a DIYI have Aclara (TWACS Signal) metering system installed on the pole at my home. PCS, WS1DL-6 UPB dimmer switches were installed throughout (60-65 each). They were receiving interference from the meter while it was reading my usage. Sierra Electric (New Mexico) asked Aclara to have my readings reduced from hourly, to once each 24 hour period at 12:00 midnight. This really helped the EXTREME flickering each hour of the day.
I still have flickering issues with both LED and Incandescent light fixtures. Sometimes a quick bling; maybe 15-45 minutes later I could get another blink or a flicker.
I have installed LDS-120 stabilizers and IRL-1oK resistors in parallel with the load/neutral on each switch with no noticeable change. I've swapped incandescent lamps with LED and vice versa; no change.
What I've finally tested was installing four Simply-Automated US40-11 dimmer switches in place of four PCS, WS1DL-6 switches. The flickering and blink issues disappeared entirely. That was great to see after many months of playing with this mess. The problem now is that Simply-Automated appears to no longer be operating their business.
Can anyone tell me why the Simply Automated US11-40 dimmer will operate the lights without any flickering and the PCS UPB, WS1DL-6 dimmers allow blinking and flickering off and on daily?
LED/CFL Dimmer (WS1DL) - Powerline Lighting Systems - PCS
www.pcslighting.com
Prediksi Macau | Data Result Pengeluaran Macau | Keluaran Toto Macau | Live Draw Macau Hari Ini| RAJABANDOT
Rajabandot adalah bandar toto macau paling lengkap, pemain yang ingin mencari apapun tentang macau sudah ada sini seperti paket komplit data result pengeluaran macau, keluaran live draw macau hari ini hingga prediksi jitu macau lengkap hadiah kemenangannya.www.simply-automated.com
I do not understand your question?This is a separate poster from the original thread, the OP is asking a question and it does not appear to be a DIY
Is it possible that a Harmonic Rectifier could eliminate the flickering issue I am experiencing? I located one at this site https://saticshield.com/energy-management-system/power-perfect-wire-in/I have Aclara (TWACS Signal) metering system installed on the pole at my home. PCS, WS1DL-6 UPB dimmer switches were installed throughout (60-65 each). They were receiving interference from the meter while it was reading my usage. Sierra Electric (New Mexico) asked Aclara to have my readings reduced from hourly, to once each 24 hour period at 12:00 midnight. This really helped the EXTREME flickering each hour of the day.
www.pcslighting.com
I don't know what a harmonic rectifier even is.Is it possible that a Harmonic Rectifier could eliminate the flickering issue I am experiencing? I located one at this site https://saticshield.com/energy-management-system/power-perfect-wire-in/
