QES
- California
can two conductors be twisted together instead of running parallel ? within code?
			e57 said:If you do it yourself, make sure it is clock-wise. (Like all pre-made cables.)
e57 said:If you do it yourself, make sure it is clock-wise. (Like all pre-made cables.) Clock-wise on a clock-wise system draws the conductors together, counter-clock-wise repells....
e57 said:Its called Transposed, or Tri-plexed...
I think that only applies north of the equator.e57 said:If you do it yourself, make sure it is clock-wise.
steve66 said:No, they are clockwise from either direction. I've already tried that with a rubber band
