Twisted Conductors
Louisville, Kentucky
Inspector
What pitfall if any would I have it I were twist three # 12 THWN together to make a "Triplex", Hot Neutral and Ground?
I would like to run one circuit out to a detached garage for a fixture to light the driveway.
Any thoughts appreciated.
Norb
Edited for Subject spelling correction.
[ September 10, 2005, 03:25 PM: Message edited by: 1793 ]
1793
Inspector
Re: Twisted Conductors
The garage is 20 feet from the house. I don't think 225.6(A)(1) applies. So are seeing that 225.6(A)(2) comes into play?
Norb
iwire
Massachusetts
Norb it is 225.6(A)(1) that applies.
225.6 Conductor Size and Support.
(A) Overhead Spans. Open individual conductors shall not be smaller than the following:
(1)For 600 volts, nominal, or less, 10 AWG copper or 8 AWG aluminum for spans up to 15 m (50 ft) in length and 8 AWG copper or 6 AWG aluminum for a longer span, unless supported by a messenger wire
That section applies to all spans less than 50'
1793
Inspector
Bob:
My bad I read that line as OVER 50'. I was wrong please accept my apology. I can use #10, my first choice. My initial question was primarily dealing with potential problem(S) twisting the three conductors together?
Again I read the section wrong.
Norb
iwire
Massachusetts
Norb no apology needed at all.
I am not familiar with running overhead conductors like you describe. I do not think you can twist your triplex out of THWN but I really do not know. :confused:
If I was running this circuit overhead I would buy triplex with a messenger or run my own messenger and attach UF cable to it.
pierre
Don't forget 310.8(D)
Example from Encore Wire, THWN: Take a look at which ones are SUNLIGHT resistant.
Solid conductors, uncoated copper, per
ASTM B3.
Stranded conductors uncoated copper per
ASTM B3, ASTM B787and ASTM B8.
Conductors Insulation:
Color-coded, Polyvinyl chloride (PVC), heatand
Moisture-resistant, flame-retardant
compound per UL-83 and UL-1063.
Jacket:
A tough, polyamide, outer-nylon covering
Features:
Slick, outer-nylon jacket for easy pulling.
VW-1 rated 14 AWG - 1 AWG, 1/0
AWG and larger is rated for CT use. 6
AWG and larger is rated for Sunlight
Resistance in all colors. All sizes are rated
?Gasoline and Oil Resistant II.?
Print Legend:
Conductor Sizes 14 AWG through 10 AWG Solid:
E123774 (SIZE) AWG TYPE THHN OR
THWN-2 GASOLINE AND OIL RESISTANT
II VW-1 600V (UL) OR AWM OR C-(UL)
TYPE T90 NYLON OR TWN 75 FT1
Conductor Sizes 14 AWG through 1 AWG Stranded:
E156879 (SIZE) AWG TYPE MTW OR
THHN OR THWN-2 GASOLINE AND OIL
RESISTANT II VW-1 600V (UL) OR AWM
OR C-(UL) TYPE T90 NYLON OR TWN 75
FT1 DATE/TIME/OPER
Conductor Sizes 1/0 AWG - 500 KCMIL Stranded:
E156879 (SIZE) AWG OR KCMIL TYPE
MTW OR THHN OR THWN-2 GASOLINE
AND OIL RESISTANT II SUNLIGHT
RESISTANT FOR CT USE 600V (UL) OR
C-(UL) TYPE T90 NYLON OR TWN 75 FT1
DATE/TIME/OPER
Conductor Sizes 500 KCMIL - 1000 KCMIL Stranded:
E156879 (SIZE) KCMIL TYPE MTW OR
RESISTANT II SUNLIGHT RESISTANT FOR
CT USE 600V (UL)
DATE/TIME/OPER
pierre
Bob
Type UF
340.12 Uses not permitted.
(11) As overhead cable, except where installed as
messenger-supported wiring in accordance with Article 396.
Art 396 permits the use of UF Cable with a messenger as per 396.10(A).
How much UF Cable do we see overhead without a messenger?
1793
Inspector
I like the idea of the UF supported by the messenger-wire. I have not done this type of installation before. Are there any illustrations showing how to attach conductors, UF, to messenger-wire?
Any help is always greatly appreciated.
Norb
tshea
Wisconsin
I have used black ty-wraps spaced about 12"-18" apart on a 3/16" steel cable messenger line. The cable is fastened at both ends to the buildings. The UF is formed into a drip loop at each end then ran into a hole in the garage, to be terminated in a 4 sqaure box (about 6" from the hole). Then a disconnect switch is installed close by where accessible.
I have also run the UF into a weatherhead and down some conduit, into a basement, then to the breaker box.
Any other ways??
james wuebker
Iowa
I think iwire was correct in staying to just buy triplex wire. It would be easier,safer and faster.
Bye now,
Jim
1793
Inspector
The one supply house I visited said the smallest Triplex was # 6. I feel this is an overkill for a 15amp circuit used for lighting on the garage.
Thanks to all who have replied. The other options posted is just one of the reasons I like this group.
Norb
