James L
- Kansas Cty, Mo, USA
- Electrician
That's what's up. It don't get any better than that, IMHOWe use to twist solder then tape. No wire nuts. This was required at Duke the early 80's in Durham.
Would that be anyone before and after Chubby checkers?This is from page 3 of our FAQ's https://forums.mikeholt.com/threads/2020-nec-faqs.2551625/
- Is pretwisting conductors required when using wirenuts?
But pre-twisters and post-twisters are all welcome here.
To me, it doesn't matter what the joint is like with the wire-nut removed.That's pretty good, but still looks like it is about to fall apart.
I am inclined to agree, but the two issues I have with nut twisting are:To me, it doesn't matter what the joint is like with the wire-nut removed.
You could say the same thing about split-bolt joints.
lazy, not easy..... the two issues I have with nut twisting are:
1. It's easy to not wire-nut-twist enough. I see that a lot. Granted that is sort of installer error, but twisting with linesman's seems more "black and white" to me.
that's user error. If none of the conductors are leading or trailing, a wire nut grabs all of them that it's rated for2. Similar to #1, The inspection issue. Sometimes one conductor doesn't get grabbed by the nut and gets pushed out. And you can't tell.
