two circuits in same wall box
infinity
New Jersey
Journeyman Electrician
Yes, it's even permitted to run them within the same cable. The only limitation would be if the adjacent devices were fed with a voltage above 300 volts between them. At that point the adjacent devices would require separation.
cadpoint
Durham, NC
Seperation after 250 V
Recall'n as long as there's not more than 250 Volts total sum, then and if after that, a physical barrier is required.
Tooth slot in mud ring for Metal divider, with plastic some have a slot for the dividers some don't.
celtic
NJ
nakulak said:
apparently its a hair dryer if you stick your head under it :grin:
Would it also qualify/classify as a clothes dryer?
:D
(lpelectric..it's too late....the inmates have now taken over :) )
lpelectric
:D
I'm running for the gates right now. Have a great weekend. :smile:
