MAC702
- Clark County, NV
Years ago, I shelved my nearly new Ideal 61-766 because the voltage readings weren't working anymore. I didn't have time to mess with it, and replaced it with a Fieldpiece as I was getting into HVAC work, and they do pipe temperature conveniently.
Yesterday, I got the exact same problem with my daily-used Fieldpiece SC240.
So I've got both on the test bench now. Fresh batteries don't help. Neither will give any meaningful readings on 120V power tests or 9V battery tests, so neither AC nor DC voltage functions are working.
The AC clamp appears to be working on the Ideal, but reads about half an amp on the Fieldpiece whether I'm measuring the 0.65A load or not. The capacitance function is working on the Fieldpiece. The temperature function (which requires removing leads, switching a rejection feature, and plugging in the thermocouple) is not working. It returns OL when thermocouple is plugged in, and cycles through meaningless temperatures with nothing plugged in, regardless of rejection feature switch (which probably doesn't switch anything else inside).
Googling the terms I can think of just returns a cascade of useless stuff trying to teach novices how to use DVMs.
