Davebones
- North Of Tampa Fl
Engineer wants to power up a test stand ( 2 - 150 hp motor's ) with 2 - 400 amp bus switches . Basically one switch to feed one 150 hp motor each . I would like them to use one 600amp bus switch to feed both motor's . The engineer says he doesn't like this because if problem with one motor then he can't run the other motor . I say all we would have to do with one bus switch would be pull out the fuses that feed one motor should we have a problem . I see this as a safety issue where I want someone to only have to shutdown 1 disconnect vs having two to turn off to work on the stand .Just looking for some thoughts on this ...
