Two Gang Meterbase Grounding Lug for Multiple Generator Hookup
Duncan8943
Lexington
I am using a two gang meterbase for a duplex. Each side of the duplex has a dedicated generator. Two ATS located beside the meterbase. Any issues with replacing the existing single wire ground lug in the meterbase with a three wire ground lug in order to connect to the ATS panels? This is a non sepaerately derived system. Other ideas are appreciated.
Are you referencing the grounded (neutral) ? How did the original neutrals terminate ? You should be able to connect just like the original arrangement.
(Just to cover the bases, are your ATSs "service rated" ?)
