TommyO
- Sunnyvale, CA
In my main service entrance panel (combined panel that has meter + breakers) the electrician has brought in two ground wires. One from the water pipe, the other from a ground rod.
They are going into different spots on the ground/neutral bus bar of the panel.
I thought that a GEC has to be continuous or connected by a "irreversible splice".
But before I ask the electrician about it (and look foolish) I thought I'd ask here.
Inspector isn't coming until Wed. So if I need the electrician to add in a permanent crimp connector between the two wires, there's time to do that.
