jaggedben
- Northern California
- Solar and Energy Storage Installer
Yes, the part about stepping down and back up again is my issue. The part about stepping down and back up again was the reason for this original 2 questions:
Are 208/480 step-up transformers a new fad? For a small island, wouldn't another set of 480 3-phase feed lines be significantly cheaper and more efficient than running 208 lines large enough to handle a 175 KVA step-up transformer and the cost of the transformer?
My initial take is:
You never save money by stepping down and back up again if you have a choice about both ends. Yes, it would make more sense to send 480 and only step down where you need to.
I'm still confused about the general design.
208/480 step up transformers are a thing because they allow connecting grid tied 480V inverters to 208V utility services. (The 'primary' should be the side connected to the utility so that makes it a 'step up'.) I don't see how they are an advantage when you're not dealing with a utility and have the available option to interconnect an inverter at 480. (Who suggested it was a good idea?)
