TeslaElectric
Inactive, Email Never Verified
- Larchwood, IA Sioux Falls, SD USA
A church expanding for the third time has 50kva 1ph 120/240V trans on the north side of building to a 200A meter socket supplying two 200A disconnects that are ~50' inside. One is a 200 main breaker with 60A subpanel and the other is a fused disconnect that feeds a MLO panel across the building. They put a walkway with fire doors to attach the first addition so they could put a 75kva 3ph 120/208V trans on the south side of building supplying two 225A panels through a 400A CT cabinet. Right now there is a 30x75 unattached garage going up for the buses to park. I am going to put 100A panel in there from the single phase service. Next spring they want to add on 20,000 sq.ft. attaching to north side with calculated load of 200A not including 2 of the 4 A/C units because they are 3ph. i asked the HVAC company to get me specs on single phase units and they dont make 7 1/2 ton units single phase i guess.. the utility company wants me to eliminate the single phase service and refeed it with 3 phase from the south. they passed inspection because of the fire doors and now have two addresses and pay two bills to the power company. it is 500' from the CT cabinet on the south side to the north side meter going all the way around the back of the property. some of which will be under the future addition. do i eliminate the single ph service? inspector wont let me feed future addition with 3 phase from south because it is attached to north part of building. if i refeed single phase service with 3 phase how do i balance the load as best as possible? i will have two 200s and a 100 from there.
any tips would be appreciated.. trying to stay sane. And i have not checked all the single phase 240V loads yet to see if they will work on 208..
