gridsolar
- California
- Solar Designer
I'm working on a residential solar project where the main service panel has one meter but 2 main service disconnects. One disconnect is a 200A that feeds a bus with some loads in that panel, while the other one is a 100A that feeds a separate subpanel in the garage. That 100A is NOT on the bus that the 200A feeds. It's like on its separate corner inside the main panel. If I were to do a load-side tap onto the feeders of the 100A service disconnect, would solar only supply the subpanel loads and not the loads connected to the bus in the main where the 200A breaker feeds?
