K8MHZ
- Electrician
Mark, 90 degree angle ... yeah, the 1200 sounds reasonable; that went to the heat recovery boiler(s?). This was at a Duke Power Buck Steam Station in Spencer NC ... then 5 coal boilers, 4 turbine generators (40, 80, 125, 125 MW) and a small "combustion turbine" peaking group (then 6 gas generators, 3 generators) with wast head boiler(s?) connected to one of the old (late 1920's) (25 MW IIRC) TG units. As best I can tell from Google Maps, that configuration still exists. See 35.712738,-80.373794 for the CT control building. We had 3,000,000 gallons of #2 to burn then.
Hot gas out of Gas Generator to inline "Free Turbine" coupled to generator
GG runs like any other 707 engine ... indeed, we bought a couple of surplus airplane engines. We had one maintenance guy who was either ex-military or ex-aviation who supervised our HSIs. These ran about 4-5 hours a day in the winter for peak loads, longer in the summer.
Imagine a boiler for a coal plant only instead of powdered coal burning inside it is the exhaust from a huge natural gas powered jet turbine. Since they were so big, they ran slow, i.e. 3600 rpm.
IIRC, the 707 used a Pratt-Whitney high bypass turbo-fan engine. 9000 rpm sounds pretty reasonable. The Pratt F-100s were (probably still are) jet fighter engines with no turbo-fan and ran at around 20,000 rpm, so 9 grand does sound like it's in the right range for the 707 engine. Man, that's got to be tough on anything connected to it.
