jeff48356
- Livonia, Michigan
Are the individual conductors inside a piece of 14/2 or 12/2 Romex cable THHN or THWN type? What about those inside of an 8-3 or 6-3 Romex?
Hey Augie, just for sake of gettin everybody in a uproar could you also tell us what the specs are for THHN insulation and THWN insulation, do they in fact specify 90* thermoplastic polyvinyl chloride with nylon jacket type insulation?
And if so, the conductors in NM-B cable are in fact the same even though the cable is not listed for use in wet location.
Next question, has anyone seen failures of NM-B exposed to wet or damp locations with a higher failure rate than any THWN conductors exposed to the same?
6.1 Both before and after assembly into finished cable, the insulation employed on the circuit conductors shall comply with (a) or (b):
a)THHN Construction ? Jacketed insulation for a Type NM or NMC cable shall have a nylon or similar jacket and shall comply with the thickness and other applicable requirements for Type THHN thermoplastic-insulated wire without (see 25.18) any surface marking of ?THHN?, ?-B? or any ampacity or temperature rating.
b)TW Construction ? Insulation without a nylon jacket shall comply with the thickness requirements for a Type TW thermoplastic insulated wire. The insulation material shall comply with (1) or (2)...
I do not think that the UL specs for those wire types say anything directly about requiring a nylon over jacket. That is there for mechanical protection and to meet durability criteria rather than as insulation per se. It is but one way to skin a THHN cat.
In earlier threads the consensus seemed to be that the conductors in NM-B may well meet the THHN or THHN-2 specification but if they are not marked as such they cannot be stripped out of the NM sheath and used that way.
Different manufacturers may use different formulations and specify and/or mark the inside conductors differently.
