NolaTigaBait
- New Orleans,LA
that's clean work...i noticed that you use that bushing on all of your service changes....what did you use to affix the panel to the wall?
Isn't it illegal to cut a hole in the back of a weatherproof panel above the buss without a suitable fitting.
Only if your planing on using it as an electrical enclosure.
Could the handhole have helped move that LB to other side of mast
Could that exposed #6 to water pipe have bean eliminated, with direct-burial clamps jumpered from same water pipe to Gnd Rod?
Well, my life is now complete...I have seen yet more pictures of all in one services and snap in bushings from 220.
I start sending them directly to your email if you like.
Don't make me look it up. My book is at the office, I'm at home.
That would be like a dream come true.
The sad thing is ............ Pete is telling the truth, he would like that.
Merry Christmas Pete. :smile:
Those are 5" blocks
If you look closely you will see that I had to go above and beyond and reroute a 1/2 copper water pipe that was in my way.
