As there are contradicting posts I was hoping an expert could resolve this.
Situation:
Existing Structure: 100 AMP Main panel w/ 2 ground rods feeding new sub panel in attached addition.
New "attached addition": 100 amp sub panel, new basement foundation has #4 copper attached to an embeded 20' 1/2' rebar with rated clamp. #2 alluminum 4 conductor is feeding this 100 amp sub off of a 60 amp breaker in the main panel. Bond screw is removed on sub panel.
Question 1. Does the #4 copper ufer wire need to be brought all the way back to the main panel, if so it's to short can it be bugged and extended. What would the proper splice method be.
Question 2. can / should the new hot water baseboard and tankless water heater be bonded to the new sub or brought back to the main panel, it's fed off the main panel but loacted in the new addition.
Question 3. Does the new sub panel need ground rods?
Situation:
