ohmhead
- ORLANDO FLA
Well in a residential service i think the code should be changed ! Heres why a ground rod or any grounding method is to equalize potential in system and protect in the event of a strike meaning a bolt of lighting or a major fault in the system ?
Does per NEC one install a grounding electrode that can handle a major problem in a residential area of protection meaning the size or diameter of a rod to a wire like a no. 4 bare or a no.6 to me is not good enough! You need protection in a area of wire size area diameter or rod to give you a good point of earth to soil not just a 20 foot of stranded conductor which to me is a capacitor each strand or conductor in that conductor at high voltage meaning a lighting strike .
Ask the power company why they install 60 foot rods down when they ground a transformer its for a good path not just a moisture connection to ground or earth like in Arizona . If lighting strikes would your house do better with a ufer ground attached to a rebar under you home or would it be better to attached to a 20 foot of ground rod its your house think about it ?
Were just giving our thoughts dont take it to be wright or wrong its just my thinking on electrical not a book .
Theres the water table in florida or other states that a ground rod is better then a ufer ground and thats common sense . Take care and yes were commercial but that has nothing to do with my reasoning on this subject if you like to debate on electrical theory were here were not here to see whos better than the other were here to talk electrical stuff ?
