Hendrix
- New England
Can the UFER ground take the place of ground rods :?
Utilities are used to ground rods, wood poles- not too many choices for electrodes that are as cost effective as a rod.Thanks, I thought that the utility always wanted gnd. rods regardless.
In 20 years new electricians won't know what a ground rod is.
Aren't ground rods those things that you hammer through underground feeders, water pipes, and gas lines?
iThanks, I thought that the utility always wanted gnd. rods regardless.
Trees don't grow that wayI have often wondered why utilities don't make their poles with a steel plate wrapped around the bottom connected to a steel rod that goes up the side of the pole in a precut channel. then they could just set the pole in the hole and connect the ground wire to the top of the steel rod and not have to run wire down the pole that gets stolen and damaged on a regular basis.
Trees don't grow that way![]()
I remember in the 70's for a temp power pole running a #6 solid copper from the meter base down to the bottom of the pole, making a little curly que of wire on the bottom, and calling that good for the grounding electrode. Used to pass too.![]()
I've seen new poles still on the trailer that are used by our local electric coop. The all have a pre-installed copper ground wire that terminates in a spiral on the bottom face of the pole just like you describe.
POCO here has that coil at the bottom as well, but they do uncoil it and connect to a rod when they plant the pole.I've seen new poles still on the trailer that are used by our local electric coop. The all have a pre-installed copper ground wire that terminates in a spiral on the bottom face of the pole just like you describe.
