HipHopHead
- NJ
- Electrical contractor
Im doing an above ground pool. My plan is to pull both the pump circuit and a new circuit for the convenience outlet through the same 3/4 pvc conduit. My original plan
was hit a timer and then put both the single timed pool pump receptacle and the convenience GFCI receptacle in the same box with a duplex bubble cover. Both outlets having their own set of hots and grounded conductors with on EG, Then i came across the code where it says "wiring must be seperate". Does this mean that they cannot be in the same box? or that they cant share wiring? thanks in advance for all the help
