I am installing gas sensors in a C1D2 room. The associated power supply is located outside the room and is UL 1604 rated. Does this mean the power circuit is nonincendive? If it is I'm planning on running the circuit in EMT, placing seal off's as required when crossing the classification boundary, do I need to use seal off''s before the sensors? Some UL info: http://ulstandardsinfonet.ul.com/scopes/1604.html
