bfro
- Orlando, FL
Per UL 83, conductors are marked "the maximum voltage for which the wire or cable is rated". That being said, does "maximum" mean maximum or nominal maximum?
I am working on a older, unique 600V system and there has been some concern with utility voltage fluctuations producing a voltage slightly greater than 600V at times. Can I use 600V rated conductors?
I have confirmed with the equipment manufacturer that the equipment ratings are nominal.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
