SSDriver
- California
- Electrician
I was wondering if anyone has a part number for the bases to mount standard single Siemens GFCI breakers in a UL508a panel. Most panels in the past use Square D mounting bases. But we have been having a lot of issues with there GFCI's tripping with inverters in boilers and on pool pumps, siemens GFCI's don't have a problem.
I'm looking for a single pole circuit breaker base that will accept a Siemens GFCI breaker (EX: QPF2) that can be mounted in a UL508a panel that has a UL listing. It would be nice to use them as standard breakers are much easier for guys to find and swap out at facilities and this way I can have all the breakers of the same style/manufacturer.
