stickboy1375
- Litchfield, CT
Sorry I can't help you there. I did not design the cabinets. All I did was electrical install.![]()
I like the electrical!
I like the electrical!![]()
Good, because the tile man chewed me out for not putting plugmold directly under the cabinets instead of the receptacles he had to cut into his backsplash and uglify his backsplash.
Picture was taken shortly after it was finished. I bet if you go there now there is things sitting on counter and you don't even notice the receptacles in the backsplash that much.
I don't blame the tile guy for being upset by those receptacles, phone jack, and switches. That was something that should have been discussed in design, or at least a different color should have been chosen instead of white.
On point with the subject though, the u/c lighting is excellent and I have yet to have any problems or complaints with linear lighting. It's perfectly uniform, so at least the tile guy should be happy about that. :happyyes:
Also, since I have never priced out Trac 12, what is the price comparison to the Seagull Ambiance? (higher/lower/equal)
Just a side note, why not keep the switches and counter receptacles the same height? I know this is just an opinion, but doesn't it look nicer?
I don't know why. I have always put kitchen counter receptacles at 42" above floor and switches at 48" to top (but usually not a disposer switch it is always 42) I guess I like to keep switches at same height throughout the place so you are always reaching at same height to operate them.
Nobody ever complains, I'm guessing they don't notice it as much as I would.
Like I said earlier, after they put some things on the counter it is even less noticeable.
a different color should have been chosen instead of white. (higher/lower/equal)
They were changed to brown when new switches were installed, and yes, my projects. Why would you have chosen black? Perhaps the picture is just showing the stain closer to that dark, but brown was the closer choice.svh19044 is this your work in post # 28 ? Nice job overall, however in the dining room photo
between the two china cabinets there is a white recptacle. Black would have been a better choice
IMHO.
svh19044, nice looking work!
It's a shame in the first photo that they have those two pillars on the island. It really breaks things up and must have made your layout tough on those recessed lights.
Normally I run my Ambiance along the front of the upper cabs, but on that cooktop counter with the stone wall I would have been tempted to run it closer to the back to bring out some texture. That looks like my kind of kitchen![]()
puck lites are so home depot... i sell NSL Xeon lights.... These are easy as pie to install!
Great choice. The only I don't like about those is that there low voltage and use a transformer. I have replaced a few of them. I try to use the line voltage Xenon under cab lights by Counter Attack.
The one unfinished pillar is actually structural in this instance, a steel jacking post, so I guess it made sense for them to incorporate the second post in to the design. I use lasers on the ground for island lighting, so it's not such a big deal to align them in the arc.
As for running the ambiance towards the back, I'm sure you have worked with soapstone as well, and it eats up a LOT of light. The task area needs all the light it can get.
Our areas of work probably overlap a little. It's nice having the customer base that we do.
Also, a showing of gc supplied lv puck lights. I'd rather eat some of the cost and throw in the ambiance than use these things. And on another note, you can see the plates low and horizontal as to not interfere with the backsplash so much. In this case, almond was chosen by the designer, but being low, they aren't as obtrusive.
I have used 12v puck lights but now I switched over to led flexible strips. I'm not really happy with the led strips. I'm looking for low cost UC lighting that works and looks good. Has anybody found this?
What issues have you had with the LED ribbon lights? I distribute/Install these on all types of application indoor and out and have not had any issues. My customers sing songs and do dances when I finish a job. Easy install, extremely low profile, long lasting, no heat issues or uneven lighting like you get with puck and Xenon make them my favorite choice. If it is the cost you should get with me I can probably get you a better deal.
I don't really care about color, so long as the color is consistent. That has been a problem in the past.
