I went on a service call today and ran into something I've never seen before.
Here's the short story. The customer has switched receptacles inside his cabinets where low voltage transformers are plugged into. These transformers control the 3 puck lights each. 1 set of puck lights were flickering and that's why I was called.
Here is where it gets goofy. If I unplugged 1 transformer, not only would those corresponding puck lights go out, but also the set on the other side of the kitchen. I checked all connections, transformers, lamps etc. but I don't know why the lights are interconnected. What am I missing?
Again, here is how they are wired. 3 receptacles in 3 cabinets, fished into 1 box in basement. Power comes from switch in kitchen also fished into basement box. 1 transformer into each receptacle. all 110v power is good and reads good. Even the low voltage tests out.
Why would 1 set of lights be dependent on anothers transformer?
