1.21 Gigawatts
- Norwalk, CT
- Journeyman Electrician
Did a search and didnt find any threads relating to this.
After running UF wire through the conduit beneath the driveway should I seal the ends of it to prevent water and dirt from entering?
The ends of the PVC stop little after the edges of the driveway which then the UF will run alone underground towards the pillar for fixtures.
Also, There is a 90 elbow currently at both ends. Is this wise to keep or will it make it worse as water drips down.
Curious if there is code for either of these and what you guys do.
Thanks.
Thanks.
