Underground communications wire. Best practice
fastline
midwest usa
Engineer
I don't usually go underground with communications but looks like some Cat6 will need to go in underground conduit. Curious what the best practice is? Being a "wet location", I am not sure if gel filled cable will be required?
I am pretty sure there is gel filled cat 6 cable listed for both direct burial and wet locations. There is no reason it has to be gel filled though.
I used a Belden CAT5e rated for that application a number of years ago, but the part number I have is no longer in existence.
It didn't have a gel in it, but white hand cream like substance that was very easy to clean off compared to some of the gels in other cables.
I have seen many applications with ordinary old Cat 5 in conduit underground working fine.
This is California though where our conduits mostly stay dry.
Cat 6 direct bury is in stock at my SH's DC. Cut to length to order.
I always use DB when I go anyplace that could have water.
If I leave a building to another building where there could be a ground potential difference, I try to use fiber or Ubiquiti, though.
if that same cable is going to run in a building make sure its also listed CMR, some of the direct burial cable has a PE jacket and is quite flammable. Ive used a ton of outdoor non-gel cable in conduit. Cable with water block tape is also a non gel option.
Depends on the application, What are you trying to accomplish? Are you extending Dmarc/Mpoe/possible Wifi into a building? Commercial, residential, or for your own home. Its best to error on the side of caution because anything UG can/will get wet, Just my 2 cents :)
direct burial is an ideal for underground use gives great protection - even if using conduit
Agree with fiber or ubiquity. Fiber is cheaper than copper. You can get pre terminated fiber with a pilling head. Multimode works well and the media converters are inexpensive
MM works well but SM is almost the same cost these days, so that's what many people are installing.
Ground potential difference? Assuming we're doing twisted-pair Ethernet, it only matters if you ground both ends of a shield, the data pairs are galvanically (transformer) isolated at each end.
