Underground for residential complex
omar
Outside the USA
Hi I was wondering if any of you could point me in the rigth direction? I'm making this residential complex and I would want it to be all underground, because normaly in Mexico it's all on post's. So do you know any spesification that I should have so I can know moe on this subject?
omar
Outside the USA
Re: Underground for residential complex
elecappren2002@yahho.com
La verdad es que necesito saver mas sobre que tipo de conductores de utilizarian normalmente para una zona residencial, porque en mi caso yo me voy a encargar de hacer el trabajo de la compania electrica devido a que esta financiada por un invercionista quedesea que todo el complejo sea suyo.
Las instalaciones normalmente constaran de 110 volts para el alumbrado domestico y 220 para equipos tal como refigeracion, equipo de bombeo para mantener presion estandar en las lineas y secadoras electricas entre otro.
charlie
Indianapolis
I have no idea what you guys are talking about, mi no hablar Espanola . However, I do know that Mexico has adopted an older version of the NEC. You can obtain a copy from the NFPA at http://www.nfpa.org :) Good luck with your project.
