Hi Guys,
I have a case where a 200A residential meter socket is not going to be installed against the side of the house, but against a brick wall approx. 10' away from it (long story). I am requiring the electrician to install a meter socket with a 200A breaker in it, and requiring that the ground electrode conductor from the ground rod and from the water pipe be installed to the meter socket since it contains the first point of disconnect. For the water pipe installation from the house out to the meter socket, I'm figuring that installing it in a separate rigid PVC pipe (schedule 40) is acceptable per 250.64of the NEC. Just looking for some verification that this approach is acceptable.
Thanks,
Creig
Thanks,
Creig
