Expansion couplings are easier to get than the split kits.
I've done it at least ten times. Works great.I am on a job that had a 4" PVC conduit damaged by the backhoe digging for the sire lighting.
To repair the 4" PVC in the trench since I can't get the pipe to bend and I only have 3' to work with, is a PVC expansion coupling acceptable for the conduit repair?
Let's get ready to rrrrrrrumble!True.
If the expansion coupling works for you, I say go for it.
Bob/iwire will now post shortly with a code section showing where I am wrong.
True.
Hey, I have ground the bump out of standard couplings so I could slid them out of the way to make room for a repair section.
Carlon for one, I'm sure there are others.I cut the bell end off a stick of conduit and use it as a slip coupling. The local utility co. has off the shelf slip couplers, but I don't know where they get them. I've never used one of those split piece repairs- Who makes them? Seems like they would be slick for the rare time when there is damaged conduit with undamaged wires in it.
