peter d
- New England
What is the length of the 2" 'sleeve'?
As I understand it, the reason you can't simply slide some 1.25" through the 2" sleeve is because of the bell ends for joining lengths of 1.25". But if you had a long enough length of 1.25" you would have no problem, correct?
Would a flexible NM raceway be suitable for the entire run, something continuous with no joints in the middle?
-Jon
He could pull 1.25" carflex/NMLTFC through the 2" PVC, but then would have to transition it underground. I don't think NMLTFC connectors are suitable for direct burial even though the conduit itself is.
