Underground wire
hnieves85
US
I sent 277v to a lighting circuit and left the numeral and ecg disconnected and the lights work. 12v from the pole to earth and can't find the splice point how is it working???
Sent from my SAMSUNG-SM-G935A using Tapatalk
hnieves85
US
It's a parking lot and I'm trying to find the splice point for the underground pvc pipes
hnieves85
US
I used a meger and the insulation is bad 5 conductor in pipe and I only connected 1 and the rest are safed off
hnieves85
US
No 480 the ballast is wired for 277 and I was doing bucket lighting maintenance
ActionDave
Chief Moderator
Durango, CO, 10 h 20 min from the winged horses.
Licensed Electrician
Fun stuff. Bet no one has an as built. My last parking troubleshoot wound up in a buried ground box that no one knew about. The only thing I know to do is start isolating connections till you find the bad junction or wire.
hnieves85
US
I'm going to use a wire tracer but wanted to see if anyone could explain how the light is working with no return to the panel
kwired
Electron manager
NE Nebraska
EC
Where did you disconnect neutral and EGC? At the fixture base of the pole, at the panel?
Do you have multiwire circuit involved here? You could have other lights in series but both across 480 volts if you do have a opened neutral and MWBC.
hnieves85
US
If there was 480 and the ballast wired for 277 then the ballast would go they are 400 watt metal halide
ActionDave
Chief Moderator
Bootleg neutral or some other alternative path would be what I would look for.
With a MWBC if you loose the neutral the lights could, possibly work through both legs of the 480V. Its possible that the lights don't blow up because even though it's a 480V circuit all the lights would be in series between your two hots. Not an possibility I would consider in this situation.
Cow
Eastern Oregon
Time to get out the locator/fault finder. I also wouldn't be energizing just a "hot" with no other wires connected.
mpoulton
Phoenix, AZ, USA
If that's a 400W ballast, the current would be about 1.5A. The 12V you are seeing suggests that the pole base has about 8 ohms of resistance as a grounding electrode that that's the return path for the current, due to a neutral-ground fault (or intentional connection) at the pole. Not a safe situation.
